apart from clutch holding tool, are there any other ways?
Discussion in 'The Workshop' started by zip-boy14, Jul 15, 2009.
  1. zip-boy14
    zip-boy14 New Member
    are there any other ways to take of the clutch instead of using the holding tool.?
  2. CheekyThomas
    CheekyThomas New Member
    Hold the rear brake on... which will hold the clutch drum still... might also need a lot of weight on the back of the bike to hold the tyre incontact with the floor for added friction.
  3. MiNoR cOnFuSiOn
    doable, but will kill the clutch shaft output shaft and all the support bearings if you keep using this technique.. 50's are especially weak/prone to snapping when you do this. altho it does work..
    impact wrench or holding tool... buy them, if you dont want to buy them dont work on your bike. need holding tools/impact wrench and a flywheel remover at bear minimum to work on these engines
