To get ur electric start going you have to pull in the brake .. if ur brake lights are not coming on .. is this the switched connected to brake leaver? and does the switched wire up to electric start to .. so if they were not working.. would the electric start work?
the brake switches sometimes fail. but most times its just the wires come off. the brake light needs to come on for the electric start to work
thanks i think they are both broke .. are they easy to replace? Thanks i think i have found the problem then just need to get them changed.. one of the brake lights were working .. then it stopped so i had neither and the electric start wasnt working so it must be that
It's a two min job when you have the panels off. They are just little plastic switches that screw into the leaver unit.
