anyone got a clue ?
Discussion in 'The Workshop' started by phil.s, Feb 25, 2013.
  1. phil.s
    phil.s Active Member
    Got a NRG power having trouble with air bubbles in the fuel pipe today I replaced the fuel lines with new braided ones a new fuel pump but yet its still getting bubbles in there and causing it to bog and cut out after 2 mins of riding the bubbles must be getting in there before the fuel pump and its stumped me so anyone who has messed with a fuel system on a NRG power please shed some light cos I'm pulling my hair out my m.o.t is due by Friday and can't get there
  2. patwk03
    patwk03 Member
    yam neos 50/yam cw70
    just put normal pipe not braided on and try
  3. phil.s
    It is normal fuel pipe except its more expensive its braided inside the rubber its not the metal braided one your thinking off
  4. patwk03
    patwk03 Member
    oh right on well have you blead the system? or are the bubbles appering as it runs
  5. Jonathan123321
    Jonathan123321 Member
    Piaggio NRG Power DD
    Make sure all the clips are on the end of the hoses correctly as that stop air getting in. Apart from that if you have changed all the pipes and the pump and have not damaged them while installation then, sorry i dont know :confused:. Just make sure all the clips r on. Theres nothing to an nrg fuel system, Vacuum pipe, Pump, And pipe to carb :confused:
  6. phil.s
    I know I was thinking the same I haven't changed the vacume pipe as that seems OK I've put new stiff clips on and there all in place only thing I can think of is the tap on the tank itself but I can't find a replacement part listing anywhere for it all I can find is vacuum taps for old NRG's. Have you tried taking yours off the tank is it even removable ?
  7. oliwest
    oliwest Member
    aerox road legal pit
    Pull the vacuum off at the engine case, i had to do it when i first got mine, pull it off an suck it, youll have to do it for a few mins then fit vacuum back on an leave i idlein for a bit then try it, mine was sorted! :)
  8. phil.s
    oli i got all the fuel system bled through fine and left to tick over for 10 mins to get some life in the battery then oncee i ride it and get past half throttle the revs die down andit tries to cut out and when i look at the fuel pipe its full of air bubbles. after this ive bled it through atleast another 5 times and it just does the same its pulling in air somewere
  9. 2many2strokes
    zzr1400
    gaskets around the fuel tap on the tank possibly?
  10. oliwest
    oliwest Member
    Could replace the fuel tap
  11. Jonathan123321
    Here is the link for a new fuel tap, but to be honest all the tap is on an NRG is bassicly a filter which you can clean :confused:, Bassicly the vacuum draws fuel from the tank through the Filter (TAP) then into the pump and to the carb. If you are getting an air leak into the pipes i would seriously consider changing the vacuum pipe its really cheap - About £ 3.00 For the lot it done mine a treat :) Also Check were the filler cap meets the tank, IF the rubber that holds them together is split - REPLACE IT that will let it to much air, i had that problem mine was split all the way round and was drawing in to much air. I changed mine and its fine now :)
  12. phil.s
    link bud to the replacement tap ? lol
  13. phil.s
    doesnt matter about the link i took it all apart again tonight i double checked all the new pipes and took of cleaned and pressure tested the vacuum pipe and its all fine i put it all back together tight and snug started it rode round for 5 mins noticed it wasnt as responsive so i new there was still a fuel issue then yep it did it again started to bog i looked down and yep the fuel pipe has a great big air bubble in it blocking fuel getting into the carb this fucking thing is really getting to me now and my m.o.t is due friday
  14. oliwest
    oliwest Member
    Just wack a pitbike tank under the seat with premix and a pipe from it straight to the carb get it mot'd then try sort it when its passed
  15. phil.s
    if i had one oli i would but i chucked all my spare stuff
