any more restrictions
Discussion in 'Scooter Tuning' started by aeroxthrasher, Apr 28, 2008.
  1. aeroxthrasher
    aeroxthrasher New Member
    i have a giannelli exhaust which has the washer taken out and rollers and i have taken the waser off the variator and i cant beat a de restricted sr are there any more restrictions in my aerox that i can take out?
    cheers
  2. alexsr70
    alexsr70 New Member
    the sr is beating you mainly because it has a 17.5mm carb compared to your 12mm.
    also just because the rollers came with it doesn't necesarily mean there perfect for your bike
    and did you upjet?
  3. Mehmet
    Mehmet Active Member
    AUDI A3
    X2 ???
  4. Mehmet
    AUDI A3
    The aerox has 62 main jet so upjet it bt 5% if you have only a exhaust
  5. chris14
    chris14 New Member
    instead of making a new topic up ill add to this one does any 1 no i was messin roud wiv ma mates aerox and was chekin it was derestricted and it was but didnt seem to be using as much as the roller ramps as mine so i took variator off and found another little washer (goldy colour) witch mighn ddosnt have so we took it out and it went faster but acceleration went poor so we put it bak ion and aceleration went good again but top speed down agen lol.
    any 1 no wot it is for ?
  6. alperin
    alperin Active Member
    aerox 180cc
    if its the little one where it goes on before the variator fan cover the last bit of the variator just leave that lol
  7. chris14
    chris14 New Member
    yh i put it back in but adds around another 8-9 mph faster without it lol
    oh well tryed it out on ma mates bike atleast lmao
  8. aprilia172
    aprilia172 New Member
    inlet manifold is restricted in aerox i think worth the 2 mins to take it off and check then its jetting
  9. aeroxthrasher
    umm wheres the inlet manifold? and how is it restricted i know i shouldnt be allowed to own a ped lol but owell im a noob
  10. aeroxthrasher
    can i put an sr carb on my aerox
  11. aprilia172
    the inlet manifold is the rubber connecting your carb to your engine, some have a restriction in this its a flap accross blocking some of the flow into your engine, you can cut/dremel em out but its easy to grind through to ther outside you can get an unrestricted one cheap enough tho if it goes wrong. the carb will work on your bike might need the new manifold though as not sure of the size of yours. not sure if its worth spending the cash for the rewards you will get, try setting yours up and getting your jetting spot on should be quick enough
