another melted 172 piston
Discussion in 'The Workshop' started by Civvy, Sep 24, 2018.
  1. Civvy
    Civvy Member
    A few weeks back I was in lane 2 on the M4. Lost all power (after 35mins) pushed it into Slouf, shoved it in the back of my daughters car and got it home and open on the bench again.
    Bright white plug (that's new) 4 corners of piston seizure.
    It's started rubbish and ran iffy for two years.
    So new PM PROX piston base gasket and a hone is in the post.
    Don't know how i'm going to stop this happening again, been asking around for years about getting it running right, think I might sell and go back to a boring Leader.
    Too much conflicting advice: some say I wasn't running enough oil, some say I running too much and making it weaker. A shop says I shouldn't be running a runner ignition on a typh engine and it was too advanced. Some say they should only be run on 98RON. I couldn't find a dyno for toffee and found it impossible to test every condition.
    The last thing i was asking advice about was when holding a speed i.e. 60 mph the throttle is on the verge of closed and the engine doesn't know whether or not to accel or decel.
    Spec
    172cc Typhoon
    180 gearbox
    full circle crank
    runner red ignition
    25mm delly
    ET2 airbox
    Standard exhaust
    100 main
    52 pilot
    100ml: 5ltrs SIP oil
    Not thrashed everywhere, it's in a Vespa built for touring.
  2. MARSH
    Get rid of the red cdi, that is the major reason , As someone told you, it's too advanced for an air cooled engine. I'd go up on the main jet a little as well using a 25mm! 2% premix. I personally like the std carb jetted upto 90-92, they work so well and not far off a 25mm for performance.
    Civvy likes this.
  3. Civvy
    Civvy Member
    Pardon my ignorance, why does the cooling affect the timing?
  4. MARSH
    A water cooled engine has a very stable "thermal stability" meaning machining tolerances are better, engine temp is a constant in all weather conditions. An advanced ignition timing creates high temps in the cylinder, air cooling can't cope. The higher the ambient temp the worse an air cooled engine will run, it can't cool itself. There is a post on this forum about such issues, the stock cdi is perfect.
    Civvy likes this.
  5. Civvy
    Civvy Member
    Cheers Marsh
  6. Civvy
    Civvy Member
    Do you think a 25mm might be too big for standard air box/ exhaust? I’ve wondered that for a while. Feels like it.
    I might try a standard carb again. The return of the auto choke would be welcome.
  7. MARSH
    It's a bit overkill with std pipe, there is std carbs on ebay, the Mikuni carb is lovely, just jet it up on the main!
    Civvy likes this.
