annoying problem! throttle response
Discussion in 'Scooter Tuning' started by ICEY CRAIG, Jan 31, 2008.
  1. ICEY CRAIG
    ICEY CRAIG New Member
    okay heres the deal i got a gilera ice, i bought i second hand but i've had it around 2 months now.
    One things thats just come on is that everytime i pull away its like its choking on it self- theres no power it just judders power then after about 5 seconds bam full power and i go.
    everything is standard atm part from leo vince tt pipe.... and de-restricted.
    Thanks
  2. ICEY CRAIG
    anybody?
  3. kyle1b1
    is it if you full throttle from pull away?
  4. ICEY CRAIG
    yea i normally full throttle when i pull away...
    but then again if i didnt full throttle it would probably be the same as if i was full throttling it lol
  5. kyle1b1
    have a play with idle mix.
  6. ICEY CRAIG
    okay, do you think my carb could be clogged up or my fuel line?
  7. kyle1b1
    no probs just bad set-up but can check for nothing.
    also rollers could be too heavy.
  8. ICEY CRAIG
    okay thanks for the information i will have a play with it 2moro and post the result :D
  9. wobbly_trials
    idle mix doesn't just change it's self.
  10. ICEY CRAIG
    what do you mean?
  11. Hursty
    Hursty New Member
    if its standard.. it cant have been moved
    ben.
  12. kyle1b1
    isnt standard. he listed loads of other parts in other thread, and more than likely had a mess with it. and like i said rollers could be too heavy
  13. MiNoR cOnFuSiOn
    oh come on....
    you have a pipe.. it wont rev off the line.. clutch springs are not stiff enough.
  14. ICEY CRAIG
    ok did what you said put some stiffer springs and some lighter roollers 3.5 to be exact
    and tbh not much of a difference still does it when coming to a corner and then pulling form it
  15. Aerox Aaron
    Aerox Aaron New Member
    did u upjet when u fitted the pipe?
  16. ICEY CRAIG
    no. im guessing that maybbe the problem? but how? i know hardly anything about jetting im willing to learn...
  17. kyle1b1
    you need to upjet around 5%. so take your float bowl off(the plastic bit on bottom of carb) then they will be gold bolts things these are jets the biggest one in the middle is the one you want. need to see what numbers are on it. then add 5% to that and just unscrew the old one and screw the new one in. refit float bowl make sure its sealed right and job done :punk:
