Hi guys I've been busy- but if you have a minarelli engine then you may find this useful http://www.scootershack.co.uk/conversations/tweaks-to-my-setup.39182/
Sorry guys - 'been busy with a CBR125R and a go pro. Taking my test in spring. But now I have some gear and acquired the bare minimum of editing skills, I can now show what I'm on about. Took the opportunity of my gal's scoot blowing up (suspect the original cause is the ignition - which is just a bit too 'hot' for day to day use. Goes like stink - but has a nasty habit of perforating pistons and generally f@#king shit up. It uses the same Stator as the MVT I use but the CDI is different (Dopller's own confection) and therefore advance is much more. You can bloody feel it too. And so can the piston. The new TPR 50 kit is a beaut though. Like a mini MHR ! New Dopppler crank (what a beaut). Should go a bit faster (TPR vs the (5 year old) Top Perf iron kit. - the TPR exhaust port is HUGE) But with the original ignition it should be more reliable too and I won't need a spare battery on charge in the winter (Post 2003 Ovetto ignition needs juice to run with the Doppler/MVT ignition because of the faxed-up CDI). That's the news ! Hope you enjoy the vids.
