air box cover not tightening up>> fucked thread
Discussion in 'The Workshop' started by Aerox-lad, Nov 1, 2008.
  1. Aerox-lad
    Aerox-lad New Member
    out of the 3 screws that holds my airbox cover on only one tightens up properly another one will tighten up but not as tight as it should be and the other one doesnt really tighten up at all. i have tried fitting a slightly larger/longer screw but it hasnt really had an affect. someone has suggested self tapping screws? would this work or could there be other solutions? cheers.
  2. MiNoR cOnFuSiOn
    an even bigger screw...
  3. Aerox-lad
    ok mate was thinking this. if i lift the cover off and try screwing in the screws with the cover off they only seem to tighten up when the screw is nearly all the way in. the screw seems pretty loose when im tightening it up and i can push it in like nearly all the way in before having to screw it in to get it further inside. (if that makes any sense)
  4. MiNoR cOnFuSiOn
    what was the point in even writing the last messager... ream a thick screw in there. slef tapping is fine. for the second time :confused:
  5. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    cant believe this is a question in the workshop section
    :wtf:
  6. Aerox-lad
    just gnna try self tapping screws. cheers.
