Aerox
Discussion in 'Newbie Scooter Tuning' started by Timmy Campbell, Nov 19, 2013.
  1. Timmy Campbell
    Timmy Campbell Member
    what speeds would i be looking at with
    Polini Corsa 70s kit
    21mm tnt carb
    Polini 9 speed Variator
    Primary and Secondary gear
  2. Dandruff37
    Dandruff37 Active Member
    Aprilia SR50 R
    What exhaust mate?
    All depends on how its set up, if set up correctly with a decent exhaust i'd expect a top speed of atleast 65mph
  3. Timmy Campbell
    I have the stage6 exhaust
  4. steveaerox50
    steveaerox50 aprilia owner
    1999 aprilia rs125
    id get a dellorto instead of a tnt carb there reputation isnt upto much , and have you changed the crankshaft for a aftermarket one the corsa kit is a bit strong for a standard crank also which model of stage 6 exhaust have you got you want one that will run with a 70 kit personally id use a yasuni r or a yasuni c16 with the polini corsa
