Hi folks, when i turn the ignition on the fuel guage and everything should work yeah ? My battery is full charged an fuses ok, the bike when key turned doesnt come on, yet when u kick start it, it works e.g the lights an indis etc so anyone have an idea why it doesnt work when its not started ? Also the seat lock mechanism, should the cable going into the ignition be loose or screwed in tight as ther is an adjuster, Cheers
Could be a dodgy connection to your battery, or a poor earth to the frame from the battery. Ooor the fuse carrier could have a dirty connection. The fuse may be ok but not actually connecting. Dunno about the cable.
Idont think there is a earth ? LOL where would it be on the aerox mate, on th nrg i believe its on the cdi ? Ta
There must be an earth! Follow the black cable from the battery and see where it connects to. Check that connection.
just a question. Did you find out what it was i have the exact same problem. I think its the relay but im unsure.
as bajaj said, your problem lies in either the Fuse, fuse holder, the earth lead (from negative on your battery to the frame), or the connections to the battery. if you have the exact same problem then chances are it isnt your relay. the main bike earth is always from one side of the battery to the frame (on all modern bikes its negative)
well i unclipped the relay before and plugged it back in and everything worked. But then it just stopped working again so i don't know. Will get this sorted tommorow along with a few other jobs i need to do. Paint the exhaust check my jets in carb etc.
