right hey guys i just finished my ped put crank in bore on carb started first time but it wouldnt go anywere so i thought id try my old 17.5mm carb but didnt start :/ so i took it off again then put my 21mm carb back on now wont even start at all their is a spark but i looked at exhaust area and found their was oil around exhaust its really pi**ing me off so any help would be wondiful
make sure jets are clean an give it a good few kicks, aerox carbs take the piss to get going after there emptyy
got the same problem here matey... got a nice healthy spark, and life, but it will not kick over and start for the life of it... it started once for 2seconds then cut out... hope u get it sorted mate
sorry for the hijack guys, but iv got a similar problem, my aerox wont start got a nice spark.. and i dont think the oil and petrol is getting to the cylinder, iv checked if the fuel and oil lines have fuel and oil coming out...but it doesnt run to the cylinder , my last piston got battered because it had no lubrication from the il... ? many thanks people if u can help
hey ive had a similar problem... took my aerox to garage in november when my m8 crossthreaded it when screwing in new spark plug -.- they changed the part that was crossthreaded then got it back and started first time and everything was fine.... month and half later and now it doesnt start :/ managed to get it going for like 5 seconds then it cuts out only way i can get it to start is if i rev it on full from when i kick start it and then hold down throttle and brake .. get on it and ride without releasing the throttle but i dnt do it coz i dnt wanna damage the bike any more :L after its been ridden down the road it wont cut out .. soo its only having the problem starting :/ not when being ridden... if any of the people above sorted there problems can u pass on how u did it . cheers
i put a new head and piston on mine,it sstarted,then the next day i started it and it was staying at high revs,checked the throttle and tick over screw,they where fine,now it just wont start..anyone help?
Hello there, I have a Aerox r 2016 with fully rebuilt engine as the con rod seized solid to the crankshaft its all back together now all brand new parts the engine is getting fuel spark and compression but it will not start atall fuse is okay as I’ve checked it’s really frying my brain any help guys
sounds like an air/fuel mixture problem to me. I had a similar problem with mine. I disconnected the air filter and placed my hand over the carb air inlet. letting my hand completely seal, then moving away gradually while still turning the engine with the starter motor. somewhere in between the engine started. then it was a very weak mixture I was getting and had to play around with it after. it might not or might help you but its maybe worth a try.
