aerox wont start after rebuild
Discussion in 'The Workshop' started by roxy boy, Mar 27, 2012.
  1. roxy boy
    roxy boy Well-Known Member
    roxi
    my pm 70 blew the circlip fell out and scrathched the barrel didnt do much damged ...it lost all compression and was kicking and it was backfiring ...but bought a new pm and fitted it went kick it and it started for about a second and will not start at all it has a new spark plug and a spark put fuel down the cylinder but will not go at all help
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    Bearings,seals ?
  3. roxy boy
    roxi
    fucking left over metal from the sheered off circlip...has damaged the barrel ...will it run it has scartched above the ports and a small one 4mm long below the port ...i am so fucked off
  4. Jonnymarrw00t
    If it's through the nicosil then you're fucked.
  5. roxy boy
    roxi
    how can i tell
  6. Jonnymarrw00t
    Generally on iron bores if you can run your finger nail over it and feel it then it's had it, Same for Ali, how I told my friends rep had had it.
  7. roxy boy
    roxi
    wt about if i get it honed
  8. roxy boy
    roxi
    will it matter as it is above the ports
  9. Jonnymarrw00t
    You can't hone a nicosil bore :/ needs re-plating....
