Aerox tunning advice please
Discussion in 'Newbie Scooter Tuning' started by Sharpey, Jul 29, 2012.
  1. Sharpey
    Sharpey New Member
    Heya there my aerox started life of as a 50 cc but I put a 100 cc aerox engine in it and have then found out that 100 cc aerox are rubbish so I am going to buy a 50 cc aerox engine and make it into a 50 again I have a 21 mm deletro carb but what big bore kit to get if I go with the polini 70 cc big Evo kit is this kit really good Or is there a better kit you people think is good and what Cdi unit should I go with and does anyone no any scooter tunning websites that will supply parts on a pay monthly basis cheers for all the help
  2. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    Get a stage6 sport pro kit, its got a good power curve and doesnt eat through pistons. You will need a good crank with any decent 70cc kit, i'd go for a PM tuning if you want something good and cheap (£90) or a stage6 HPC which is more expensive but said to be tougher.
    Aerox's arent restrcited in the cdi so a standard one will be fine.
  3. Sharpey
    Sharpey New Member
    Ok cheers so do you think the stage 6 kit will be better than the polini big evolution 70 cc kit and what do you recommend I want to make it quite fast cheers ?
  4. FiddyRox
    I'd say the port pro mk2 (stage6) will be a better all round kit for everyday use.
    A good setup would be;
    Your 21mm dellorto
    Stage6 Sport Pro mk2
    Performance crank
    Yasuni c16 exhaust
    Polini or Stage6 reeds
    Malossi Variator
    PM tuning clutch
    That would be a seriously fast bike. My aerox has a PM crank, Sport Pro mk2 and polini reeds but only a doppler pipe and 17.5mm carb, and it lifts the front a few inches off the floor when i give it full throttle and wheelies with ease when im actually trying. Does near enough 70mph now too.
    A gear up kit would be a good idea but usually the stage6 kits wont need one because they rev so high (even better with the c16 exhaust)
  5. Sharpey
    Sharpey New Member
    Ok cheers I was finking about polini Evo 70 cc big bore kit the polini big eveoloution crank that you need to go with it and the polini big eveoloution exhaust you need aswell and polini 9 speed super speed variatior do you think that would be better but cost like nearly 800 pounds or do you think I should go with the kit mentioned above will there be much difference cheers
  6. murerg
    murerg MBK Hero!!!
    Polini evo isnt made for everyday use. You are looking at a lot of maintenance with that kind of setup.
    ..and i ve never heard of a scooter shop that sell on credit or monthly payment.
  7. Sharpey
    Sharpey New Member
    Aww ok cheers what would you say is the best kit that has loads of power and is good for everyday use cheers ?
  8. murerg
    murerg MBK Hero!!!
    cast iron kits are better in term of longevity.
    Polini sport, malossi sport or s6 streetrace do work well :)
