aerox tuning
Discussion in 'General Scooter Discussion' started by chris14, Feb 22, 2008.
  1. chris14
    chris14 New Member
    after reading a lot of topics every body seems to say u should put a new variator on as one of the first tuning things u do 2 a 50
    why is this what diifernce does a better variator do?
    ill have an aerox soon and will hpojng to put a 70 kit, 21 or 22 mm carb eahust and do u think i will need a upgraded variator for this set up ?
    what make 70 kit, carb, eahust and variator if u think i need 1 would be best for as little money as possible?
  2. Jamie
    :msn1:
    polini sport 70 kit, dellorto 21 ml carb. lazer x pro exhuast 4.5-5.5 g rollers
    slightly stiffer clutch springs
    no variator.
  3. chris14
    chris14 New Member
    cheers for that dya rekon i shud get a kevlar belt aswell to be on the safe side and what kinda size mj would i have to order if i get a dellorto carb with the polini sport 70kit?
    does any 1 no wot the pm tuning 70 kit is like or is it a waste of time
  4. Jamie
    how many miles has your bike done?
    if its done alot then mayaswell change the belt aswell.
    well capri dave on here has a similar setup and i ""THINK" hes running around a 75 main jet
    never used a pmtuning 70 kit so not going to comment on them but i havent heard anything bad about them and theyre single ringed kits so probabally quite powerful.
  5. chris14
    chris14 New Member
    fnx for that and i havnt got an aerox hopefully getting 1 at the weekend or sum tym soon enyway as im sellin my trekker on sat hopefully and just tryin to plan it all out in what im going to do when i get an aerox and the price its all going to cost
    pm tuning seems quite cheap do u no wot those endy pipes are like or best to go wiv lazer x pro or sumular
  6. frazer
    frazer New Member
    not alot of people rate the endy zorsts but alot of people rate the lasers
  7. chris14
    chris14 New Member
    oh rite
    wot bout the Giannelli 1s my m8s got 1 and he rekons its a gd 1 sounds nice aswell
  8. Dec
    Dec Active Member
    nothing ugm
    endy exhausts are awful m8 i used to have 1 (it came with the bike alright :p ) and gianellis are good for accelleration but lazer would work among the best with the setup jaimie recommende tbh hope this helps
    dec
  9. chris14
    chris14 New Member
    cheers fnx for the advice
  10. MiNoR cOnFuSiOn
    if its a gianelli reverse go for that.. if its any other moddle go for the xpro..
  11. Boost ya scoot
    Boost ya scoot New Member
    i mate
    i would get a stage 6 70 kit, 19MM dellorto carb, yasuni R exhaust, malossi var, kevlar belt.
    but on the cheap side
    stage 6 70, 19MM dellorto carb, leo vince zx, rollers and belt
    Cheers BYS 08
  12. Nitro-Rhys
    Nitro-Rhys Active Member
    dont go for a stage 6 if you want reliability, stop advertising just cos your an 'official dealer'
  13. Boost ya scoot
    Hi mate
    the stage 6 cylinder are reliable and it is not a advertising thing at all mate just giving the lad some advice
  14. White aerox
    White aerox New Member
    mate they aint relibale my mate had 1 and yes it was fitted by a shop and he had it 3 weeks and it went puff! lol
  15. Sw1fT
    Sw1fT Active Member
    200SX S13
    lol, stage 6 has a bigger part of your signature then you're own company does?
    and single ring "race" kits are reliable are they?
  16. chris14
    chris14 New Member
    getting confused now what to got for got choice of 3
    polini 1
    pm tuning 1
    or satge 6 1
    more people seem to rate the polini 1 for reliability tho
    what will the best 1 actually be then ?
  17. kyle1b1
    polini
  18. chris14
    chris14 New Member
    ok cheers
  19. Boost ya scoot
    hi mate
    the stage 6 logo is bigger than the name because we are proud to sell stage 6
    and the stingle ring is ok just need good oil and run it in
  20. chris14
    chris14 New Member
    dnnno even were i can buy stage 6 kit from so ill most proberly 110% go wiv polini or pm but there single ring aswell so proberly i will get polini as you can get spares easy enough aswell
