aerox tuning
Discussion in 'Scooter Tuning' started by nath09, Sep 23, 2010.
  1. nath09
    nath09 New Member
    speedfight 2 mhr 70c
    well i aint been on ere for agerss. but i need some help so i fort i would see if any you guys can help me :D right iv got a aerox siting in the garden and im getin abit of money soon(i hope any ways lol )and i whant to do the aerox up the the max the normal 70cc exhuast and every thnk els and i whant it to be just as fast as some of the peds u see on you tube like soon as u touch the throttle your on the back wheel kinda thing
    ere is just couple vids
    http://www.youtube.com/watch?v=uaZplv5F2BQ&feature=related
    http://www.youtube.com/watch?v=UGdFvur6buk&feature=related
    http://www.youtube.com/watch?v=pjAdnfbWhSc&feature=related
    you get the picture so if any one can help then would be greatfull soz to go on btw lol
  2. zipSP70
    zipSP70 Member
    Piaggio Zip SP 70
    if you want a bike that powerful u will need to spend BIG money
    something like:
    malossi mhr/ polini evo 70 kit
    full circle hpc crank
    bigger carb and reed block kit
    variator, clutch
    high end race exhaust
    race ignition/ rotor
    this sort of spec will set you back about £1000. and thats not including additional engine work, porting, polishing and tuning
    if money isnt a problem you can spend 3 grand upwards on a fully tuned out engine. the videos u showed also have big bore kits. This is also more money and will also give more power. there are many displacements from different companies (77cc, 84cc, 86cc, 90cc, 94cc)
    obviously you can cut back and spend less and still have a quik ped but it wont be as quik as in the videos
    hope this helps mate
  3. Gilly-93
    Gilly-93 Member
    Aprilia Sr70
    How much money :grin:
  4. nath09
    nath09 New Member
    thanks mate helps alot and for money well it goin to be bit of a on goin thing erm i hopefully wil b getin 800quid soon and thats all goin on the ped i was thinkin about getin the polini 94cc kit crank to go with it n the exhuast and every think els ?
  5. zipSP70
    zipSP70 Member
    Piaggio Zip SP 70
    £800 spent on tuning with th 94cc will give you awesome power
    the 94cc kit isnt exactly over expensive neither. but you will have to modify the engine cases to take the bigger crank and kit. best leaving it to a professional if you dont have the knowlege.
    good luck with your tuning! keep us updated :)
  6. nath09
    nath09 New Member
    so if i got the 94cc kit it would b quick and powerfull like the vids ? lol and ye ri no you got to do some modding what exsacly is it you have to modd to make it fit if could help woul db great?
  7. zipSP70
    zipSP70 Member
    Piaggio Zip SP 70
    you need to grind the crankcase a little to take that kit
    best if you leave it to a scooter/tuning shop. where abouts are you from?
    yeah it should be something similar if you get the pipe, carburettor and 9 roller variator to match. but wont be as revvy unless you have some porting to the cylinder.
  8. nath09
    nath09 New Member
    i am from portsmouth? and yer ill props do all that get polished n ported just give it to shop n let them get on with it lol ha
