Aerox tuning help... Hello :)
Discussion in 'Introduce Yourself...' started by Jimmy yates, Mar 14, 2012.
  1. Jimmy yates
    Jimmy yates Member
    I'm jimmy and I'm from England (Kent) I'm building an engine for a Yamaha aerox and basically need information about the most important things that need to be done, I under stand most thing but not too sure on ignition timings and how to adjust them, Im planning to put on the stage 6 racing 70's, Would it be alright with the pro replica? I already ordered it, Would I need any porting done? Thank you for all the help
  2. roxy boy
    roxy boy Well-Known Member
    roxi
    no as its not a high end kit and yes the pro rep would be good and look on a youtube vid tht would be the best help as you can follow along with the vid ...youtube is a god ,,when your stuck
  3. Jimmy yates
    Jimmy yates Member
    Ok mate thank you
  4. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    As for ignition timing, the CDI has a set curve and timing so there's no need to change anything around :) Which crank are you going for?
  5. Jimmy yates
    Jimmy yates Member
    Ohhh right, should be okay then, I already have a racing cdi on there on my aerox, but nothing major is modified on that engine at the moment, I'm going for the stage 6 hpc crank man :)
  6. FiddyRox
    Sounds good to me :) It's gonna go really nicely when it's all set up, what carb have you got? And variator etc?
  7. Jimmy yates
    Jimmy yates Member
    Well at the moment Im only working on the crank casing and just getting basic ideas on what to get set up, On my aerox now I have a Polini high speed 3 gram, Polini race belt (Had it for 350miles and it's tearing already!), The clutch is standard, Parmakit 50 top end, Racing cdi, kundo power pipe, Standard carb and air filter, I'm planning to get on the new engine a stage 6 19mm race carb, Gonna be a pain in the arse setting up the carb but should be worth it
  8. FiddyRox
    Don't worry about jetting the carb being a pain the arse, the guys on here are great and you will find a basic guideline. Saves a lot of time.
    Setup sounds good, id recommend a pmtuning clutch though. Would you sell me the parmakit 50 top end? I need a standard crank too...
  9. Jimmy yates
    Jimmy yates Member
    Yeah man I'll let you know how everything is going and I'll let you know as soon as I got it up and running then I can strip the other engine mate :)
  10. FiddyRox
    Nice one :) I'm doing a budget rebuild, but luckily I have access to engineering facilities so I'm gonna have a standard cylinder bored out to 70cc, and get some decent bearings on a standard crank.
    Won't go anywhere near as well as yours but it will be fast, and will cost about 40 quid haha
  11. Jimmy yates
    Jimmy yates Member
    Yeah that sounds like a good idea, Haha, My engine at the moment is really good to be fair, For a 50s kit i have overtook some 125's and most mopeds, it's not tooo bad, Get roughly 55-60 on flat and downhill it goes past the "temp" writing but that's a mega hill lol, Hopefully when this engines all finished I should get a solid 75? But I want it mostly for low and mid range because i prefer to be quicker of the line than top end
  12. FiddyRox
    Yeah mine goes surpsprisingly well for a 50, it got a ported cylinder, polini reeds and a carb and pipe. Goes really well of the line, the pmtuning clutch helps a lot.
    I keep up with my mate on a 125 4 stroke that's had some work done, hopefully when my engine is done I'll fly past him ;D
  13. Jimmy yates
    Jimmy yates Member
    Yeah man that sounds good, Where did you get your cylinder ported? How do you know of you need it ported or not? I don't really understand porting at the moment as I've never really been explained it :)
  14. roxy boy
    roxi
    You would need a gear up to hit them speeds
  15. Jimmy yates
    Jimmy yates Member
    Yeah I know, not to sure what one to go for, I think i would go for the stage 6 one
  16. roxy boy
    roxi
    Any really don't really matter they all do same thing
