aerox too much air
Discussion in 'The Workshop' started by robhall123, May 8, 2011.
  1. robhall123
    robhall123 New Member
    okay so i just put my 17.5 carb on my aerox i have a manual choke bike so i put a electric choke on so i could use the carb , it was all running fine a few leaks but i fixed that , my fuel tap is broken and it puts fuel in the engine 24/7 so i was working on the carb and clamped the hose finished my job and forgot to unclamp it ran the bike for a sec and it was fine i went to ride it was fine then cut out i forgot about the clamp so i took it off and made sure the pipe wasnt creased went to run the bike i usually throttle to start i didnt have to thought oh right so then i went off it was normal then it just bogged stays at idle goes to a little bit of revs then boggs put my finger over the air box hole and it would rev like normal what could be the problem ??
  2. scott15
    scott15 Member
    Want an NRG MC3
    what filter have you got on it?
    what size jet do you have?
  3. robhall123
    blocked jet but thanks for the help
