Aerox stage 6 sport pro help!!!!
Discussion in 'General Scooter Discussion' started by Jimmy yates, Apr 28, 2012.
  1. Jimmy yates
    Jimmy yates Member
    Would this cylinder kit be alright for the standard crank???? It's either this or the street race!! Need advice! Thank you
  2. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    Have a look at the pedparts blog. You might be okay with the streetrace provided that your crank is in good nick and low mileage. The issue is one of revs most of the mild sports kit hit their maximum power at arond 9500 revs and then it starts rapidly tailing off and at 11000 revs it's somewhere about 6bhp. The stage 6 kits hit their maximum power also at about 9500 revs but hold it to 11000 revs before tailing off.
    A standard crank is okay with the higher power at 9500 revs but is starting to be stressed when it's still there at 11000 revs. so the combination of high revs and high power is the problem.
    This broad band of power with the stage 6 kits is great as you don't need a gear up kit. The other kits need a gear up because to increase speed when the variator is wide open you need power and this is where the other kits start to lose it.
    My Aerox is fitted with the streetrace 70 kit and a Top Racing (Doppler) crank because that way I had the performance and the comfort of knowing that the crank (which can rev to 15000) is understressed.
    So you pay yer money and you take your choice Stage 6 and crank or other and gear up kit.
    Many streetrace kits are used on bikes without new cranks but just remember not to screw it all the time, but then you don't need to as they're plenty quick and you cant ride everywhere knocking 70.
  3. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    Well said mr bizzle, what does your Ped top out at?
  4. wedgie
    wedgie Member
    Mk 1 Zip SP
    I've got a streetrace for sale right now mate! got a slight score, needs a new piston but the rings are fine! PM me if you want it for cheap!
  5. Jimmy yates
    Jimmy yates Member
    Oh right!!! Thank you for that information mate, I won't be thrashing it top end as I only really want it for acceleration, I have a parmakit 50 ATM and hits a good 65 down hill, I want to get the hpc crank but I think I'll have to have a garage to replace it Becauae Im not good with taking all the engine apart and setting ignition timings and stuff all again
  6. Jimmy yates
    Jimmy yates Member
    Also what roughly is the running in milages? For the street race thanks
  7. FiddyRox
    For a streetrace I would say 150 miles
  8. Mr Bizzle
    04 Aerox 70 stage 6
    I've been clocked at 70mph.
  9. Mr Bizzle
    04 Aerox 70 stage 6
    You don't need to set up the ignition timing. The stator plate is unbolted to remove it and simply bolted back on to replace.
  10. Jimmy yates
    Jimmy yates Member
    Oh right so how do you set the timing then?
  11. FiddyRox
    Its a fixed position system, it all going back together and stays the same mate
  12. Jimmy yates
    Jimmy yates Member
    Oh right so to actually set the timing you have to take it apart?
  13. FiddyRox
    You can't set the timing, the flywheel only goes on in one position mate
  14. Jimmy yates
    Jimmy yates Member
    I'm confused lol I thought by turning the stator advances or retards the ignition timing but you have to take all that off to change the crankshaft
  15. FiddyRox
    Correct, but on an aerox the stator bolts on in one position and cannot be turned to advance or retard the ignition.
  16. Jimmy yates
    Jimmy yates Member
    Oh right, that's really unusual so do you need a certain tool to change it or something?
  17. FiddyRox
    No mate it just unbolts, most stators can turn because the bolt holes are elongated,maerox ones are just round holes so it's in the right position when you bolt it on.
    You will need a flywheel puller
  18. Mr Bizzle
    04 Aerox 70 stage 6
    As Fidddyfox says, it's really simple and you can't go wrong. You will need a flywheel puller though.
  19. Jimmy yates
    Jimmy yates Member
    Sounds unusual lol
  20. FiddyRox
    What year is your bike?
    My puller might fit, you can borrow it if so
