Aerox, someone help.
Discussion in 'General Tuning' started by Jimmy yates, Jul 22, 2012.
  1. Jimmy yates
    Jimmy yates Member
    Does anyone know what mm before tdc should it be sparking, I have a Yamaha aerox. Thanks
  2. murerg
    murerg MBK Hero!!!
    Are u trying to fit a new ignition?...
    Not sure about the exact reading as on a standard igni you use the small bit on the crank to get it right. You shouldn't have to work it out manually no?
    Internal rotor igni have different timings depending in the model.
  3. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    According to my manual its 14 degrees btdc at 5,000 revs.
