aerox slow on accelation
Discussion in 'Scooter Tuning' started by aerox-liam, Apr 21, 2011.
  1. aerox-liam
    aerox-liam New Member
    rite ive got a 2007 aerox brought as a non runner put new spark plug in and it was running now ive put a new belt spark plug air filter standard it has a leo vince exshault on it put brand new 6 gram rollers in started it up when for a ride but seems not to go into high revs unless im going downa hill its very slow 2bh could this be my clutch at all ive ordered one i noticed it has a blue contra spring is that a problem for its accelation at all?
    help will much gratful many thanks liam
  2. robhall123
    robhall123 New Member
    okay mine does the same thing put some 4.5 g rollers in might help i mean i havent got my setup sorted out yet , and check for air leaks and stuff because mine had the exact same problem and i found that the air box manifold wasnt on properly
  3. robhall123
    oh and check the jet if its too high it kills the acceleration mine was standard 86 i just changed it down to 76 and it flys
  4. aerox-liam
    what is the standard jet on a aerox how much should i go up by ?
  5. aerox-liam
    any more news on why my aerox will be slow at all blue polini torque spring aproblem? and what size is the carb jet standard?
  6. wobbly_trials
    86 is the standard jet i think.
    jetting shouldn't be too far out on a leo pipe
    i would drop a standard contra spring in and start at about 4.5 on the rollers, also run standard clutch springs to start with.
  7. aerox-liam
    ok thanks for that ive put standard contra spring in and have new clutch on it and done rollers and which has made a lot of difference only problem now is a have a bit of flat spot at about 15 mph and then again at 45 anythinng to do wiv carb reed or the jet?
  8. Sheridan16
    Sheridan16 New Member
    i have simular problems but at 30 and 40 and my bike was running decent and then i put ma pm tuning clutch and its just lost all power basically , i was using the blue springs with it. does any1 kno ? shall i down jet to 72?
