aerox shenanigans
Discussion in 'Scooter Tuning' started by KyleH, Dec 4, 2013.
  1. KyleH
    KyleH Member
    Aerox 11 Plate
    okay so my aerox 70cc is running sweet as a nut, fueling properly power in all the right places ect but the only trouble is that the bike seems to 'bog' for a second before it pulls off, the throttle is responsive once moving but its not as good as i want it from pull off. Is this a problem with the rollers or is it the carb?
    Setup:
    70cc streetrace
    pro rep exhaust
    malossi multivar
    17.5mm carb
    3.7g rollers
    stage 6 medium spring
    malossi red clutch springs
    kevlar belt
  2. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    Hi. I'd try riching up the mixture screw 1/4 of a turn. Worse ? Go back to where it was & do the opposite. If that does nothing good - go back to where you were with the screw then try some black omega springs in the clutch - or a 0.4 mm washer on the variator (more belt slip at the start).
    Good luck -
