aerox setup
Discussion in 'Scooter Tuning' started by Leeroy, Jun 9, 2007.
  1. Leeroy
    Leeroy Member
    my mate has a aerox with a
    malossi sport 70s
    malossi reedblock
    malossi manifold
    21mm carb,
    malossi air filter,
    malossi variator,
    malossi belt, and a malossi rep exhaust
    at the moment it has a 94 jet in that the shop put it, which is silly overjetted and the rollers are all wrong, can anyone recomend what roler size and jet to run
    cheers!
  2. gazell
    gazell Active Member
    not got a clue tbh but i'd reccomend him getting some dyno time that way he'll get the best setup possible for his engine
  3. MiNoR cOnFuSiOn
    thing is ive had bikes setup on the dyno and the shop was hot.. so once the bike was outside the jetting was lean as hell an neerly blown up. dyno's arnt the be all and end all but give great info you can use to set the bike up. you should still fall back on riding/listening even after a dyno.
    as always, jetting and roller guides on the main site wich helps you understand how it works rather than just asking for a rough jet. be nice to figure it out yourself ay? :D
  4. Leeroy
    Leeroy Member
    thanks minor il have a read and a play about :p
