aerox setup rollers and springs? help
Discussion in 'The Workshop' started by Marcus t, Aug 3, 2012.
  1. Marcus t
    Marcus t Member
    Hi I've got a full stage 6 setup
    Stage 6 crank
    Stage 6 streetrace
    Stage 6 variator and drive face
    Stage 6 clutch and clutch bell
    Stage 6 v force 3 with carbon reeds
    21mm dellorto carb
    Malossi e13 air filter
    Stafe 6 pro replica exhaust
    I'm currently using hard clutch springs and 5gram rollers and a medium toruqe spring do ou think I need to go lighter than 5 g rollers and also as I'm using hard clutch springs do you think I would benefit from putin a hard tourqe spring in thr wat rollers do you recomend for mysetup also could I put a standard airbox back on if so wat jet would I have to use as I wnt to try and make my bie abit quieter as its toooooooo loud lol thank you in advance
  2. 70ccAerox
    70ccAerox Member
    from reading a little on here id be guessing the rollers are too heavy and should be around 4grams
  3. tommo10
    tommo10 Member
    aerox70 kx250
    i got about 3.5g with my streetrace and yasuni z. So yes, i would defo go lighter
