Aerox running problem- please help...
Discussion in 'Scooter Tuning' started by aidanbean, Oct 30, 2011.
  1. aidanbean
    aidanbean New Member
    Hello,
    Malossi sport
    21mm malossi carb
    Polini high flow filter
    Yasuni r
    ETC...ETC
    (not even run in: about 30miles use)
    Basicly it was running fine- riding it pretty much all day on and off, left it for half an hour went back to it at like 8pm tried starting it, and then it wouldent start- eventually got it going it would run on idle but as soon as you touched the throtle it would just cut out. kept trying but it still doing the same... The following day (today) its doing exactly the same.. it had a size 70 jet so i put in a 82 still the same tried a 92 and its still doing the same it runs as ive got it running at the minute Its been running for about 15 mins on idle but still as soon as i touch the throttle it will still just cut out...
    I just think its a little bit strange as i was riding it perfectly fine like half an hour before :blink:
    No idea what it can be...
    any help would be great :beg: ??
    Thanks
  2. aidanbean
    Also no rain/water what so ever the roads were bone dry...
  3. aidanbean
    Hellooooo- right, figured out what the problem was turns out that it was that one of the petals on the redblock snaped off, only issue now is is that its gone under the crank... Fml... but one of my mates who works in a garage on bikes recons that it should be allright due to it only being fibre glass and it will just break up and go out the exhaust kind of thing.....
    Do you recon it will be ok??
    Thanks
  4. stkflote
    stkflote Member
    zip 2t cat
    yes it will be ok ive had it happen to on brothers typhoon,he just fitted a new set reeds and its been ok for nearly a year
