Aerox revving high
Discussion in 'The Workshop' started by Folz, Jun 10, 2010.
  1. Folz
    Folz New Member
    Hi,
    Ive just dragged my aerox 50 out of the shed after a year of not riding it. I've cleaned out the carb & fuel line to get it to run, but it revs its nuts off as soon as it starts.
    Only mod is a Gianelli extra & matched rollers
    What could be causing this?
    Thanks
  2. capri dave
    capri dave Active Member
    depends what you mean by revving its nuts off really :glare:
    maybe an air leak or a sticking carb slide or throttle cable...
  3. wobbly_trials
    seconded, my initial thoughts were either a sticky throttle or a split inlet manifold.
  4. DUNKMAN
    DUNKMAN Member
    yamaha neos 50
    try draning tanks and tubes then refilling with fresh 2stroke and petrol,, check transmision is all ok,check fuel pipes havent perished,,could b no 2stroke
  5. c0nn0r77
    c0nn0r77 Member
    Aerox 70
    What was the problem as im having the same after fitting the carb.Thanks
  6. Chubz
    Chubz Well-Known Member
    70cc Aerox 04'
    could be your throttle cable, i had same problem and found my cable was rubbish.... also a new belt
