aerox rear light
Discussion in 'The Workshop' started by aeroxthrasher, Jun 23, 2008.
  1. aeroxthrasher
    aeroxthrasher New Member
    the rear light on my aerox is not working when the engine is on but itworks when the brake is applied how would i fx this
    cheers
  2. Jefr0-180
    Jefr0-180 Active Member
    It's the bulb. It's a twin filament bulb.
    It has two wires in it. When the lights are on, 1 wire will light the bulb. When you apply the brake the other wire will come on.
    So you just need to replace the bulb as the normal light wire has broke ;)
    Common problem.
  3. aeroxthrasher
    cheers m8
  4. Aerox-lad
    Aerox-lad New Member
    definately bulb mate same happened with mine about 2 weeks ago. buy a new one theyre only like 1-2 quid
