ite boys lol im tryin im tryin just w8ing on shitty 50 kits feel like im 16 agen lol h8 w8888888888in
50 Kit Nibbles: I've got a 50 kit if your still after one. Brand spanking new, bought it as I changed the logbook back to 50 from 70 and wanted the paperwork in case I got chased up on it :whistle: PM me if your interested, otherwise it's going on flEaBAY one I can be arsed to list it.
right finaly got some loot n projects coming on. got kick start casing arriving soon and will be painting it soon i gtta new battery today n got it wired up iv got power to indis and lights ect but starter button does jack .iv wired up the earth that goes near the starter motor checked fuse near battery followed wire from ignition everything fine .every wire is connected but wen u press kick start button is does nothing any one no wats wrong help v appreciated
Not to sure on connections etc but switches are prone to failing. If WD40 doesn't work then maybe a new switch unless someone says check this wire etc.
can just hotwire the starter motor (puit the motor cable straight to the batery) to see if its that thats fucked.. sounds like switch or relay tho.. or immobiliser depending on the bike.
right starter mtor works changed the swith changed what i think was the relay and the cdi but no look im stuck guys need some help
have you checked that the break switch is working on the lever as they are a common fault on aerox's.
yes ill do this tomorrow am i right in thinkin you can pull either leaver in to start it like on most other peds as its a bit suspect if both are gone
