Aerox Problems Back to Square One
Discussion in 'The Workshop' started by jeremy bayliss, May 23, 2012.
  1. jeremy bayliss
    jeremy bayliss New Member
    As you may have read in my other post the bike was running ok now it is slow on hills again
  2. Stathis
    Nrg Power 70cc
    any other info you can give us on this?
  3. jeremy bayliss
    If you read my other post titled Aerox Problems Please Help it will give all the info
  4. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    Hi again, the problem last time was exhaust related and came about following repacking the end can. You fixed this problem, by repacking and the bike ran okay for a while but the same issue has returned.
    I would firstly suspect the exhaust again as the original problen manifested a while after repacking which sounds like the same circumstances as now. My dad had a friend who worked for the AA, he used to say most cars break down through a lack of neglect. In other words if it aint broke don't fix it . I suspect that repacking the exhaust has caused a problem which takes a little while to show, it may be that the packing swells or moves when it has been used for a while and causes an obstruction. My advice would be to have another look at the padding.
  5. jeremy bayliss
    Good idea I`ll have a look this weekend and keep you posted
  6. Mr Bizzle
    04 Aerox 70 stage 6
    What exhaust pipe is fitted?
  7. jeremy bayliss
    le
    leo vance tt
