Aerox problem..
Discussion in 'The Workshop' started by Crana, Jul 19, 2008.
  1. Crana
    Crana Active Member
    Built my bike up today and I changed the jet size before I started the bike up because it was the standard 86 and I put a 96 in. the bike worked fine before the rebuild with the standard jet size in (Spark plug was blackish) and now I have to keep the revs up or it will cut out and it spluters a bit and doesn't go as fast as before o_O
    Any ideas here is the jet to big? :confused:
  2. Aerox-lad
    Aerox-lad New Member
    try the standard jet again mate. or it sounds like the idle mix is out a bit. im not a pro on carbs by any stretch of the imagination tho m8. but id try standard carb. why did u strip down the engine?
  3. Crana
    Crana Active Member
    Main end bearings went.... worked fine before this tho and Nothings changed expect the jet so it must be that :confused:
  4. alex_1966
    alex_1966 New Member
    mai jet is only used at fullt hrottle , it has no affect on the bikes idel speed, sounds like the mixxture needs tweking, can happen even if you havent played about with it
  5. Crana
    Crana Active Member
    Tired everything to get it going today but it wanted none of it! :mad:
    Now I'm just going to split the engine again and start over I must have went wrong some where :wallbash: :wallbash: :wallbash: :wallbash:
  6. Aerox-lad
    aeroxtard haha. this is wahat happens whren u buy a v reg!
  7. Speedy 172
    Speedy 172 Active Member
    haha your a tard because you own a 80 mph fully derizzed aerox :w00t: :w00t: :w00t:
  8. Dec
    Dec Active Member
    nothing ugm
    1-0
  9. Speedy 172
    :cool: :pimp: :punk:
  10. Crana
    Crana Active Member
    My V reg would piss all over your rossi pile of shit
    I split the engine again im im going to start over...
  11. Speedy 172
    good luck craig if you wanna hand im free sat ?
  12. Crana
    Crana Active Member
    Just finished I just need a 10mm bolt and a 17mm bold that I'm getting 2morro nd some petrol :D So i'll update you tomorrow with the out come :)
    You still coming out on sat?
  13. Speedy 172
    yea man if its sorted il brin ya to mine to see the speedy ?
    come on msn :rtfm: :rtfm: :emb:
  14. alexsr70
    alexsr70 New Member
    meh, the tardness just comes out of nowhere when you buy a rox loool
    could be air leak maybe or even oil seals, would put money on the oilseals tho mate....
    good luck with it
  15. Crana
    Crana Active Member
    took the variator off to find the oil seal was right off as well... so me nd my dad cleaned both cases on and sealed them again and I managed to round a head nut off tho :emb: and the variator nut :emb: :emb: So I'm getting them 2morro morning :D Other then that I need to put the pipe on and put itthe engine in the bike :) My bike is now pre-mix since my dad lost the pin that drives the oil pump :unsure:
    Speedy what you doing on Wednesday? If its working I might pop up to have a look :D
  16. alex_1966
    get a decent socket set or learn how to use it ;) :D
  17. Crana
    Crana Active Member
    got one ;) The nut was rouned off before I done anything :( I made it worse...
  18. Speedy 172
    driving lesson wednesday hows thurs friday ?
  19. Aerox-lad
    my bike actually goes 45 but it dont brake down every 2 minutes :bird: :punk: ordered my laser x pro and getting a sport 70 soon though :pimp:
  20. Crana
    Crana Active Member
    Fuck it... done 40 miles last night and it sounds like a washing machine again o_O I give up
