aerox problem
Discussion in 'Newbie Scooter Tuning' started by decwhiteoak95, Aug 18, 2011.
  1. decwhiteoak95
    decwhiteoak95 New Member
    hi i have a yamaha aerox 50 on a 02 plate it has a power pipe it is a yasuni end can with a techno expansion chamber ive been told its been de restricted and being up jetted but it only does 38 mph tops.
    is this correct ?
  2. grantmc3
    grantmc3 Member
    piaggio nrg mc3
    check your variator for any restrictions
  3. decwhiteoak95
    what shall i check for?
    im new to this
  4. xplicit vehicle
    xplicit vehicle Member
    PGO Big Max 50
    well, since ure new im gona assume u dont have the tools for this. u take off ur tranny case cover and the pully on the left u undo. but ull need a special took to take it off or an impact gun. when its off behind the belt there will be a small washer, u remove this and assemble everything back together.
    theres loads of videos on utube. variator restrictor
  5. decwhiteoak95
    yes that has already being taken out it has standard rollers in and a size 100 jet?
    is this why?
  6. xplicit vehicle
    PGO Big Max 50
    ....why is there a 100 jet in there.. u only upjet a slight bit
    order a box of jets from like 60-80 or whatever they do
    and a box of rollers. u drop a gram in rollers.
