Aerox problem
Discussion in 'The Workshop' started by AeroxJoe, Apr 16, 2011.
  1. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    Hey lads and lasses
    I was on my 2002 Rox last night, out for a little ride
    And it didnt seem as fast as it normally is
    and then it started bogging, popping and cracking and then died
    it starts, revs til a point where it bogs :/
    i checked the plug, and cleaned the jet out
    i had some comtaminated fuel in it the other day, but i drained that out and cleaned the tank and carb with new petrol :) and it ran fine after til last night
    I did put some premix 2 stroke in to my tank, Fuck knows why :/
    But could that be the problem? because its getting too much 2stroke
    or is there a air leak somewhere?
  2. scott15
    scott15 Member
    Want an NRG MC3
    Would just smoke a lot if there was too much oil in it. unless you like emptied a whole bottle in it? haha
  3. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    Well it smokes like a fucking crack head :/
    so thats the problem, premix 2 stroke and plus the 2 stroke is mixing and making it run like a bag of shit?
    it had ran fine before i put premix in it
  4. scott15
    scott15 Member
    Want an NRG MC3
    yes it will make it run poorly. Depends how much you put in?
  5. scootercooter
    scootercooter Member
    yamaha aerox
    if the problem still occurs check your ststor coils, i had the same problem and thats what cured it.
    if not,just put more petrol in the tank and it will dilute the mixture and solve the problem
  6. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    cant be precise how much 2 stroke went in to my tank, stupid of me now, it wasnt much, 200/300ml :/ so if i put more petrol in my tank. give it a good old shake around and it should dilute it more?
    Cheers lads
  7. tErr0
    That will be a huge amount. And if you are still running the oil feed it will be even worse. If your bike is still running the oil pump etc then i'd drain the tank and fill it with just petrol.
    300ml even at the richest oil ratio you would ever want to run would be enough for about 9-10 litres. Much more than is in your tank.
