Aerox Problem
Discussion in 'Scooter Tuning' started by Louie.Aerox, Apr 3, 2009.
  1. Louie.Aerox
    Louie.Aerox New Member
    Hello everyone.
    I brought a aerox in january and had nothing but problems with the piece of shit the set-up atm is..
    Malossi sport 70's
    hebo clutch
    hebo variator
    PM tuning gear up
    stage 6 pro replica
    4.2g rollers
    100 jet :O
    19mm dellorto carb black edition
    the bikes at first was terrible was bogging out all the time and only going about 35mph the accelerationthe bikesflys off then after about 5 seconds it bogs down.Took it to a garage and they found the manifold was too big and put a smaller one on, got the back bike and it was a bit better it got up to about 45 and the bogged down a bit lol and then would build back up if u was on a straight road. Then the bike fucked up again so me and my dad have stripped it down about 1000 times had a look at carb, changed rollers etc... and the bike is still fucking up it just bogs at about 35-40 and sometimes will build up eventually on a long road. so can someone give me some suggestions to what the problem could be.
    Thanks.
  2. [-Jebus-]
    [-Jebus-] Member
    sounds to me like rollers? :confused: too heavy methinks, well from what i gather when it comes to rollers anyway, don't take my word for it though =)
  3. Vesta
    Vesta New Member
    Did you buy this from birmingham or somewhere beggining with B lol
    post a pic up im sure i remember the exact same bike with the same problem the bike had neons etc
    Have you checked your piston/barrel?
    also what kinda air filter you got?
  4. Louie.Aerox
    Brought the bike in bristol m8 lol heres a pic
    i havent checked piston and barrel no, and i got a polini filter on it.
  5. Louie.Aerox
    yeh scott something init?, im from dundry m8, did the bike use to do this when u used to go out with him.
  6. MiNoR cOnFuSiOn
    wtdf is it with aerox owners... transmission/jetting guides in the guides section.... maybe LOOK befor you post
  7. Louie.Aerox
    The adaptor rubber has split all the way around so gotta get a new one but was just wondering if a standard adaptor 22mm would fit? the 25mm i had on there split and had a jubalee clip really tight on it so would a 22mm fit?
    Cheers
