aerox piston blown or not ?
Discussion in 'Scooter Tuning' started by aerox crazy, Apr 19, 2010.
  1. aerox crazy
    aerox crazy New Member
    Hi need help
    Riddin the rox along a road , then it suddenly started to go slower and slower , then started to move like a standered rox , then just cut out.
    Was steaming abit from cyclinder , piston still moves but i have lost alot of compression
    Will not start atall , took the engine out but cannot get the barrel off this time ? any help
    Does it need new piston ect ect , or just a new head gasket set , tho i did fit a set prob 100-30 miles ago :confused:cratch:
  2. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    done the rings by the sounds of it.
    get it off, only way to find out the damage
  3. Spectre
    Spectre Member
    Katana-R, Runner 125
    What was stopping you getting the head off? its just a few nuts holding it in. give it a light whack with a rubber mallet if its a bit sticky, but it shouldn't be difficult to remove.
    I notice you said you have low compression so i would assume it hasnt siezed up.,
  4. wobbly_trials
    sounds like a seize to me, whip the top off, like has already been said, its the only way to tell.
    causes could be one of many things.
