aerox is slow
Discussion in 'Scooter Tuning' started by White aerox, Jan 4, 2008.
  1. White aerox
    White aerox New Member
    Hi my mate has an aerox 2002 with a malossi 70 sport kit, multivar, technigas exhaust, mhr reeds, delta clutch it has the lot and my bike with just an exhaust and multivar seems to be just as quick can you tell me why it is so slow thanks?
  2. fuj_yammy54
    fuj_yammy54 New Member
    whats the top speed???
  3. White aerox
    well its slow acceleration but has goodish top end
  4. fuj_yammy54
    you've probably reached ur maximum top end just by removing the restrictions and fittin and racing pipe. if the speedo goes off the clock to what it says is about 55 - 60 then youve reached ur maximum top end..
    i duno about ur acceleration tho you've probably set sumthin up wrong or ur expectin too much from it. play with ur mixture needle n lean it abit but not too much..
  5. White aerox
    ok rhanks mate mate and expectin to much lol na its shit slow for a 70 trust me
  6. White aerox
    ok thanks mate and expectin to much lol na its shit slow for a 70 trust me
  7. wobbly_trials
    Rollers and jetting assuming everything else is as it should be.
  8. White aerox
    rollers are fine he just got new malossi ones and jetting we will have a look
  9. wobbly_trials
    are they the right weight.
    it could be anything really.
  10. tweak
    tweak Member
    Rider's weight? :pimp:
    Poorly set up I imagine. Yeah its got everything, but fitted and adjusted correctly?
  11. steve-k
    steve-k New Member
    its a process of elimination mate, start with simple stuff then get into the more technical stuff if it doesnt get better.
  12. White aerox
    yep was fitted by a good friend who has worked with scooters for 10 years riders weight lol he is pretty big
  13. White aerox
    will do mate cheerz we are stripping the bike now so lets have a looksees
  14. capri dave
    capri dave Active Member
    its gotta be a set up issue...its not about just bolting bits on you know ;)
    When you say the riders heavy...how heavy exactly??
  15. White aerox
    its not just bolting bits on i just said a good mate fitted and setup everything perfectly and weight lol 15st but anywyas it used to be much faster.
  16. tomo9992
    tomo9992 Member
    RS125
    well sumats not setup up right some where, like steve said it looks like its gunna have to be process of elimination.
  17. capri dave
    so your saying your mate has fitted a 70 kit and a load of other bits and the ped goes slower!!
    something is either fitted wrong or more than likely its not set up properly ;)
    15 stone is fairly heavy...but a well set up 70 should cope pretty well!!
  18. White aerox
    well being far i forgot to tell u its done like 5k miles. and it is props a blocked jet, pipe or sumit cos it seems to not be getting enough fuel
  19. wobbly_trials
    what jet is it running?
  20. steve-k
    steve-k New Member
    also what carb has he got?
