Aerox is crap up hills :S
Discussion in 'The Workshop' started by AeroxJoe, Jan 8, 2010.
  1. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    Right , after fitting my Polini Racing 50 kit, and my 17.5 mm carb
    the bike runs fine on flats and downhills
    going up, its like walking speed
    it wont go fast :confused:
    Someone told me my contra spring is to heavy, and my dad told me my crank seals are gone
    i give it full throttle, and no change
    help please:)
  2. capri dave
    capri dave Active Member
    difficult to give an answer without a bit of back ground info :confused:cratch:
    when you start going up hill, do the revs start to die??
    if so your rollers are probably too heavy...
  3. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    yeah they do dave, the revs start dying out, so basically all i needed was new rollers and not new crank seals ?
    If so, my dads an ass, ordering new crank seals for me, lol
  4. capri dave
    if the crank seals had gone, the general running of the engine would be pretty rough,
    as extra air would be sucked in past the leaky seals...
    1 way to check the seals for sure is to take your variator and stator off, the seals will be visible then...if there seams to be a lot of oil around that area, then thats a sure sign the seals are leaking ;)
    but from your description i would say its a transmission/roller issue :good:
  5. Blue dwarf
    Blue dwarf New Member
    To check any suspect air leaks wether crank seals/manifold etc. run the engine and spray round the suspect area with WD40, this will temporary seal the leak and the engine revs will rise or stabilise.
  6. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    ive tried the WD40 test :)
    its fine, but like Capri dave said, might be my rollers which are making it shit for hills :(
    but my new crank seals will be here tomorrow :)
    so ill fit them, and put my old rollers in
    i have 5grs in atm :/
    i have like 3.2gr spares :)
  7. Blue dwarf
    5.0g are too heavy anyway (std are 5.5g)
    Try something like 3.5 to 4.3g depending on pipe.
  8. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    Ive got a Leo vince TT exhaust and malossi clutch, so the clutch springs i dont know about,
    the rollers were what my mate gave me, i have my old yammy ones, but there worn on oneside, not much, just a bit, can i still use them ?
    or is it best to buy new ones.
