aerox help
Discussion in 'General Scooter Discussion' started by Timmy Campbell, Jul 23, 2014.
  1. Timmy Campbell
    Timmy Campbell Member
    Hello i'm currently experiencing some problems with my aerox 70, My current setup is stage6 mk2 racing 12mm, stage6 hpc crank, 21mm stage6 dell carb, malossi variator with 4.3 gram rollers, I also have stage6 primary gears and a yasuni R exhuast and the standard airbox with the snorkel removed, I have just put a 1000rpm torque spring in with the weakest malossi clutch springs, I've tried a 88 and a 92 jet and it struggles to move I was wondering if anyone could help??
  2. Merlin
    Merlin Old School Biker
    2007 TKR WRC 50
    Maybe a worn or slipping drive belt..?
  3. Timmy Campbell
    belt is brand new mate and I dont think so mate when I took the air box off I put 90 jet in it and tried it and it was fine the power was straight their but when I put the air box back on my ped wont move or run right ..
  4. 4strokelover
    4strokelover Active Member
    Longjia Raptor 200
    Adjust the air screw and then try
  5. Timmy Campbell
    Should I turn it in or out ?
  6. bogey
    bogey Active Member
    You could start at 1 1/2 turns out from fully closed. Just make a note how many turns you had to turn it in as a reference.
