hi guys need help wiv my aerox the bike is a 2011 with a stage 6 pro rep exhaust 68 mainjet 4.5 gram rollers new standerd clutch and mallosi springs and variator washer removed the bike was running fine untilll a few weeks ago wen i noticed it pulls off normal but loosing power in the mid range and and bogs down a bit and pick's up speed again anyoner know whats causing this any info apreciated thanks.
Can someone help me i have got a yamaha aerox 59 plate its a full pm tuning bike. Everything is 70ed and it use to do 75 easy and then all of a sudden it gets to 50 and it is revving really high and sounds like its gonna blow up. It has had a new 70 kit put on new clutch new concha spring new rollers and there is still no difference. Can anyone help me or got any ideas
Make sure you have done the variator nut back up properly! I did not do it up properly when I changed my rollers The teeth on my crank where stripped as a result and i'm in the middle of replacing it now
