aerox fuel and vacuum hose sizes.
Discussion in 'The Workshop' started by Ben Petrie, Jun 18, 2016.
  1. Ben Petrie
    Ben Petrie New Member
    Hi. I am trying to find out the size (diameter and length) of the vacuum and fuel hose from the fuel cock to the carb on an aerox 2009. I want to put a valve in the vacume side so I can prime the float bowl manually but don't want to strip the carb out and measure the hoses. Thanks
  2. Markie76
    Markie76 Member
    Hi,
    Welcome to the forum.
    My guess the fuel & vacuum hoses would be standard sized 5-6mm diameter hose.
    Length wise I wouldn't expect them to be longer than a metre - unless the scooter has a special routing of the hoses/location of fuel filter.
    I imagine you'll have to remove some bodywork and the seat to fit & secure your valve anyway so you might as well go the whole hog and replace the fuel & vacuum lines.
    Thx
