I've managed to get my aerox on the road eventually thing is it jus aint fast enough here's the spec Polini sport 70s Stage 6 pro rep exhaust Polini variator 4g rollers Standard clutch with yellow polini springs Stage 6 sub frame with direct inlet 17.5mm dellorto carb Stage 6 double filter Polini Kevlar belt It's running on a premix of 33:1 as I have no oil tank and hits around 60mph from what my speedo says but is slow until 20mph n will rocket to 60mph ? There must b something wrong surely I've seen people on here sayin they get 75+ with this kind of setup please help
Don't always take what others say about their set up as gospel mate,frankly some of them are talking out of their a...s. Cast about a bit for advice/opinions - if you're perfectly straight about your set-up and results,you will find some quite sorted people on forum to help you out. .
Ok lol well that's my set up ? Plus malossi reeds n standard crank lol It jus seems dead for what I've spent
Please don't tell me your following someone elses lead?,might be setting your expectations too high! , Only been on forum for cple mnths but have noticed aerox's quite popular you're bound to find more authoritive advice (into older air cld 'peds / last bike i tuned had sprockets!), Best of luck man. .
