Aerox Engine
Discussion in 'Wanted' started by Warnsey, Jun 24, 2008.
  1. Warnsey
    Warnsey Member
    Wanted
  2. jennings1992
    jennings1992 New Member
    will have one later this week. does it need to be running?
  3. Warnsey
    Warnsey Member
    Running prefferably but if its not it would depend what is wrong with it
  4. jennings1992
    well im buying a bike to break and it has no keys i think. so i cant get it running :( so it would be a case of it may run but i cant test it. and befor anyone says no it is not stolen i have had the reg and frame number checked by the dvla and they match and are not stolen
  5. J-Nitro
    J-Nitro Active Member
    o have one needs a rear hub, possibly a new crank , top end
    has a magneto that fits up to 2004 plate wiring looms on it though
  6. Warnsey
    Warnsey Member
    ahh rite ok wel il probali intersted in the one with no keys.. il take the risk like what plate is it and how much?
  7. jennings1992
    its a x reg 2001 i think has been sat in a garden for 3 years under cover :confused: so untill i get it i do not know the condition. but i imagine if it had the spark plug in and it has been covered the engine should still be ok and just ned a good clean. but untill i get it i cannot know for sure. call it £40 without a wheel? if its all in ok condition this is? its completely upto you mate and ill let you know when i get the bike around monday.
  8. Warnsey
    Warnsey Member
    Ok wel my aerox that i need a engine for is a 98 reg so i might need the loom aswel? i'm not to sure? would you be able to post it at all?
  9. jennings1992
    i think it would have to be couriered. it would be the same loom as yours as its not newwer then 02. not really sure how much a courier would be mate but theres probably a few people on here that have done it befor and they may be able to tell you how much they paid
  10. Dec
    Dec Active Member
    nothing ugm
    j nitro paid about 30 quid i think with back wheel if i remember correctly???
  11. jennings1992
    thanks dec rossi. i imagine it would be abit less then if theres no rear wheel. still around 25 probably. if you do want it ill try and hotwire the bike to try and get it started. will let you know when i v got the bike.
