aerox engine gears making horrible sounds
Discussion in 'The Workshop' started by aerox1995, Jun 7, 2011.
  1. aerox1995
    aerox1995 Member
    noticed my aerox engine was leaking oil it was a day or two after i filled it up i thought i over filled it so i left the oil to drain off the gearbox started making horrible sounds and now it sounds grindy when it moves do you think it is fixable or would i need a new engine casing , if so i need to find a seller
  2. eddo241
    eddo241 Member
    NEOS
    Re: aerox engine
    there
  3. aerox1995
    aerox1995 Member
    Re: aerox engine
    need the disk casing really because i already have 2 neos casings :/
  4. tErr0
    Re: aerox engine
    Why are you trying to sell the guy something for no good reason?
    You over filled the gear box oil?
    I would strip down the gear box and have a look for any unusual wear or grinding marks, built it back up, fill it up with the right amount of gear oil and see if you still get any unusual sounds.
  5. aerox1995
    aerox1995 Member
    okay ill try and get that done at the weekend , its always made a strange noise from day one
