aerox electric start problems
Discussion in 'The Workshop' started by jono, Jul 25, 2011.
  1. jono
    jono New Member
    hey my aerox starts first time on kick .
    but the electric start doesnt work at at all.. it recently had a new ignition fitted and a new battery and a new starter motor but still nothing, it didnt work before those were fitted and still doesnt, all the lights work (rear , brake, headlights dipped and full beam) indicators also work but only when the moped is moving , when the moped is at stand still the indicators dont flash.
    please help me
  2. creditz
    creditz Member
    Speedfight 50 AC
    If it's moving and it doesn't work then check all the contacts and connections, i got pulled over the other night for a fault back light which all it was; was a dodgy contact... took me 5 mins to fix it! The electric start could be a wire loose or the bendix in the engine casing broken... need a little more information, i'd take your side casing off and see what it's like.
    Dan
  3. aeroxR50
    aeroxR50 Member
    aerox 100 project
    exactly what happened to mine and it turns out a wire had erodded and become disconnected from the regulator which is on the head set next to the ignition barrel...guarenteeed!!
