aerox derestriction
Discussion in 'General Tuning' started by Edgar, Aug 11, 2011.
  1. Edgar
    Edgar Active Member
    hi , bought my 2010 aerox , already removed the variator washersbut it only goes 45 now o_O , i looked at de restriction guide and the pipe there got a connection in the middle of it , mine dosent its a plain tube, i was wondering how do i remove restrictor from there? i will try to cut off the extra pipe soon , but just want to find out so i can remove that one as well , and will this give me like 50-55mph? if not is there any other stuff i could change to make it go faster something not that expensive like rolers or maybe even variator? i only want it to little bit faster as 55 its all i need ,
    thanks
  2. xplicit vehicle
    xplicit vehicle Member
    PGO Big Max 50
  3. Edgar
    Edgar Active Member
  4. Jonnymarrw00t
    Piaggio Zip 05 plate
    Dude sorry to say you wont get anywhere nere 50 with a standard bike probs just about push 40, Get a exhaust,70's on there :) Have you took the Restrictor out the Variator too ?
  5. Edgar
    Edgar Active Member
    mate im getting 50 on big road when i bend down...... all i need is to get the restrictor out , and yes i already removed the variator one :)
  6. xplicit vehicle
    PGO Big Max 50
    wait, so u dont have TWO pipes then? its just one ? theres no restrictor? well then its either not restricted or it is but ure better of buying a new pipe
  7. Edgar
    Edgar Active Member
    yh thanks for help ,
  8. Edgar
    Edgar Active Member
    got it off today, cut off the extra pipe , and the restrictor was there its like a little plate that was covering the most of the pipe inside so took it off, i sprayed it and left it for the night to dry out ,
    just wanted to ask will i need to up jet it? i got a set of dellorto 6mm jets will they fit in aerox standard carb?
    thanks
  9. xplicit vehicle
    PGO Big Max 50
    some people say upjet some dont, best thing to do is run it and see if it has any signs of running lean. and im not sure about the jets, just see if it fits not hard job
  10. Edgar
    Edgar Active Member
    :good: ill try everything tomorrow , thanks for your help mate
  11. Jonnymarrw00t
    Go up two sizes it's just to be safe :) You're not geting 50 dude. Unless it's down a big ass hill lol.
  12. Edgar
    Edgar Active Member
    i tested it and it does 50 now and bit more than that from hill :D but i got the carb out and the jet there is really weird its not like on piaggios, and it dont even say the size on it , ill try get some pictures .
    but do i really need to upjet it if it runs good?
  13. Jonnymarrw00t
    You're not geting 50. more 40. 45 at most. And is it a gutner carb ? and it's more of a saftey aspect.
  14. xplicit vehicle
    PGO Big Max 50
    im really not sure about stock exhausts. all i can say is just do a plug check if ure not sure.
  15. Edgar
    Edgar Active Member
    how can you tell me that im not going faster than 50 when my clocks showing that + i checked it with my dads car it goes 54 , and i would upjet it if i could get them jets from anywhere?
  16. Jonnymarrw00t
    -_- same thing I here every bloody time. Clock speed is inacurate. The only way to get the proper speed is with either a dyno or a good gps. no mechanical clocks are acurate. Up to 15mph out sometimes. My zip clocks showed 72mph with a exhaust.... when it was doing 45 lol. That's how bad they get. You can buy jets from any where mate. Post a picture of your jet, Should be able to tell what one it is you need. try http://www.pedparts.co.uk/ http://www.scooter-attack.com/
  17. tErr0
    Clocks over read on both a car and a bike. Down hill means nothing as well. If I jumped off a cliff i'd be going pretty quick but I wouldn't claim I could run that speed...
  18. Edgar
    Edgar Active Member
  19. Edgar
    Edgar Active Member
  20. Edgar
    Edgar Active Member
    ordered a single one from ped parts , found out that stock size is 62 so got my self a next size :64 , thanks for hep lads!!!!! :good:
