Aerox cuts out
Discussion in 'The Workshop' started by mca6969, Jul 16, 2008.
  1. mca6969
    mca6969 New Member
    (i have used the search but cant find anything pecific)
    Well first i have a yamaha aerox 08 and it had done 800km sumin nd its started to cut out when idling. Not only this but the acceleration, top speed and hill speed have all decreased and im unknown to why ?
    could this be a spark plug or a carb problem. (btw i have checked the comprestion of the engine and its fine)
    Please help
  2. stephen_h
    stephen_h Member
    have you checked the usual things such as spark plug, rollers and jets to see if there blocked
  3. mca6969
    mca6969 New Member
    i have checked the spark plug and tried cleaning it but im not too sure how to no if the spark plug is fouled for the jets, no i havnt. But i asume the rollers are fine
  4. stephen_h
    stephen_h Member
    take ur plug out and connect the ht lead backon it. then place the end of the spark plug on your frame and use the kick start and see if you have a strong spark. just be aware of the way that you do this so you dont get a shock. and the only way to see if you have a blocked jet is to dismantle your carb im affaid.
  5. Aerox-lad
    Aerox-lad New Member
    does the bike bog out alot like die down?
  6. eddiesmith
    eddiesmith Member
    i hd just the same problem wiv my aerox few months back. i checked all the usuall stuff and ended up just tweakin the idle mix, havent had the problem since. sayin that i have no idea what caused it to begin wiv becus it was running fine for months with that idle setting :(
  7. Aerox-lad
    mine cut out in the wet when i first got it . put a bit of vaseline around the plug cap and its ran well ever since
  8. mca6969
    mca6969 New Member
    i took the spark plug off and i could not see a spark but i could hear one (like on an electric cooker) And yeh it bogs down then cuts out but on full throtle it just has less power but wont cut out. i rang the people who i bought it from they sed cus its a new engine it just needs tuning and it could be the spark plug as well :(
  9. Crana
    Crana Active Member
    Sounds like you need a newspark plug.....
  10. mca6969
    mca6969 New Member
    wel i will try a spark plug first
    Do you think there could be another problems with my aerox other than this spark plug?
  11. eddiesmith
    eddiesmith Member
    i would say jetting could be off, but this shouldnt be a problem on a stock bike. u got any tuning parts fitted?
  12. alexsr70
    alexsr70 New Member
    never heard of one of them :w00t:
  13. alex_1966
    alex_1966 New Member
    you sure that click isnt the realy because they dont make a sound when they spark :wtf:
    take the spark plug out and wrap a peice of wire round the thread and ground it to the bike by wrapping the other end round the exhaust or something attach the ht lead and kickstart it, you should see a plug
    doubt its a sparkplug problem though, sounds like jetting , whats the colour of the plug ?
  14. RY4N172
    RY4N172 New Member
    take the fucker back its udner warranty.
  15. mca6969
    mca6969 New Member
    na no tuning parts on it, and i have just taken the "fucker" back today hah
    hopefully they will find the problem and fix it, if they tell me the problem i shall tell you. The colour of plug when i took it out was back on the groves around the top and sort of a really light lellow on that arm thing, sort of almost white
  16. mca6969
    mca6969 New Member
    just to update everyone if they care, well it has been at the garage and was sposed to be done yesterday where the garage sed it had a carb problem and is not fixed yet. they phone again today and tell me they have not diagnosed the problem still :confused:arc:
    soo fucking annoyed!
