aerox compression
Discussion in 'Scooter Tuning' started by aerox-deacon, Jun 27, 2008.
  1. aerox-deacon
    aerox-deacon New Member
    got my motoforce crank and my polini corsa kit fitted and it says its a high compression crank but i didnt think that it would have that much compression is it ament to have tht much that you can hardly kick it over??
  2. Crana
    Crana Active Member
    You should still be able to kick it over no problem.. :confused:
  3. aeroxthrasher
    aeroxthrasher New Member
    might be a little tight untill uv fully run it in
  4. Dec
    Dec Active Member
    nothing ugm
    get some wd40 on the kickstart mech and push it down by hand a few times that should loosen it up.
