Well i got sick of the belt slip , i went and got a red contra spring then did what every body would I pulled it down and gave the cases a bit of a tickle this way i can install my fully circle crank as well and maybe the inner rotor i spent a bit more time shaping into the boost ports this time the last cases i did i dont think flowed as much into the boost as they could have i have it sitting there now with the jb weld going off and a quick sand blast tomorrow then back together ]
Thanks guys tomorrow i will finish them off and take better pics i have yet to sand blast them to create a uniform surface And i will also take some more out and Im thinking about redrilling the breather holes in the bearings as well i dont like the fact that they go against the flow and i want the bearings to get the best lubrication possible
lookin REAL good. best mina ive seen tbh. verry similar to the shape i use in cases. there terible stocfk when you look at a decent engine. should work well tho. boost feeds arnt all that important tbh. too much flow will throw the gasses too high in the barrel and not catch the transfer charge.. has to b extreme to shoot this much in but you dont want the easiest path to the barrel to be viua the boost port thas for sure
Thanks Minior yeah i understand what you are saying This cylinder doesnt have the transfer flow i am really wanting so just trying to get all the flow out of it i can I am going to take the cases out further on the side to help it to supply all it can im also going to open out the cylinder a bit more as well tomorrow to allow the transfers to really flow more I really want this thing to hit like a mother fucker
quality work; I'm always impressed by porting, such a blackart, wish I had the skill to know how to do it efectively
Thanks it just takes miles behind the grinder to get it sorted You just have to get in and do it Normally what looks good is about right , when it comes to case flowing that is you just want the air fuel mixture to get a good shot at the transfers At 11000 rpm the time is limited for it to get there so it need the easiest path , this brings up your volumetric effciency and away you go I am still debating if to change the crankcase bearing lube holes Im going to have a look when i get to work this morning I dont like the idea of the way they flow and i just think it would be better to have them working with the flow than against it Just have to redrill the cases and fill the old ones Just getting low on jb weld some people say to do it other people say not to I will take some good quality pics when they are all done today and post them up thanks for your encouragement guys
poke a lil straw i there and backfill with chemical metal... then snip and sand. will still be the same hole but ALOT less disruption to everything. less work than redrilling aswell
Here is the curve i will be running This thing has to blast of the line i want people to go what the fuck happened to my car as it blows there doors off
Whats X and whats Y axis? I gathered X is RPM but can't work out Y? As said before. Looking good mate :beer:
Thats right and if you make the right shape it makes shit go fast You get it wrong and well you get to buy a new piston
i am so impressed by your work wax, takes me a while to catch on to half the stuff you and minor are saying here , but deffinetly learning something here. keep up the work fella as its superb. minor you know too much man
i recon wax probably knows a fair bit more than myself.. ive just been fucking about with shit bikes far too long
I wouldnt say that I jsut come from building two strokes in a different sport Im just a pup in rrgards to scooters
