Making the can would be the easy bit The hard bit is doing the diffuser cone Its hard to role it that small , the easy way would be to make it in small pieces and then weld it up but that will be the next thing I am going to use my old zip engine and then make it up using that its a longer term project
Ok i just finished porting up the cylinder it somces in at 194 degrees exhaust and 127 transfers I wouldnt mind a few more degrees on the transfers but it will have to do I may bring the cylinder up .5mm and that will bring me into a 130 degree transfer as well as 197 exhaust Much better for a top endy cylinder I will just skim the top of the cylinder to get my squish where i want it after that
its a ported up motoforce cylinder it will go fine They say these are good for 12-16 hp i am hoping for the 16 sort of power I guess time will tell , as long as its enough to power stand i am cool with that I dont actually care about top speed as long as it go likes a fucking cut snake up to 80k I like making people in cars go "what the fuck was that"
get yourself a 172 engine built and go for a ride down the motorway then LMAO can always send you a case seing as you cant find them there
yea i love the look on a drivers face when you rip past them :rofl: theyre just sat there like WTF :wtf:
ok i have seen that one before I just cant be bothered welding in new mounts etc for it if there was one that bolts in i would be doing it for sure
On another note here is my jetski i am working on this is my new race ski the engine is an 8mm power valve with 48mm carbs and 7 transfer port cylinder etc etc http://www.youtube.com/watch?v=SEPRki9bC8k
well just put one of my programable jetski ignitions in the aerox as well made a massive difference to the performance its now slipping the belt off the line so i am looking at a red contra spring i think
Not when you know how if you go to www.waxracing.com you will see i actualy make igntions i am also working on a universal one that will go onto all scooters soon and be programable as well At a reasonable price as well I will let you know when it comes out
This is my tuning aid it does egt engine temp as well as rpm it data logs as well you can buy them on ebay cheap as well a mychron II plus
