aerox breaking
Discussion in 'For Sale' started by nrgandy, Feb 27, 2009.
  1. nrgandy
    nrgandy New Member
    full aerox being split for spare no frame engine runs etc just ask for what u want and ill get pics
  2. billy_sr
    billy_sr New Member
    Front panel homey :pimp:
  3. nrgandy
    nrgandy New Member
    panels ures then ill get pics and come on msn at about 7 so be on billy
  4. rideorcollide
    rideorcollide Active Member
    TYPH 172
    rear master cylinder.. will fit a runner right?
  5. billy_sr
    billy_sr New Member
    koooooooooooooooooooooooooooooooooool :pimp:
  6. safekyle
    safekyle New Member
    Gilera runner 172
    Electric start switch n the little panel with the wires. ?
    I might want some more bits as im building up a rox.
  7. nrgandy
    nrgandy New Member
    it might but i also have a dragster one which will work ill get pics of both
    and kyle ill get pics of them bits and which lil pan with wires on
  8. safekyle
    safekyle New Member
    Gilera runner 172
    Urm i mean hte electric start panel with the button n the two wires ? should be if its the 50 as i have the 100 one here and that has the 6 wires block connection and i need the 2 block one :rofl:
  9. wobbly_trials
    Forks, front caliper and wheels?
  10. Vesta
    Vesta New Member
    have you got the water cooling cover on the cases?
    (for nibbs)
  11. jak kez 187
    jak kez 187 New Member
    have u got the starter motor ??
  12. billy_sr
    billy_sr New Member
    yeh i found him a red one on that swapz website, dont know if he took it up, because on ebay they where wanting around £45 just for the water cover :w00t:
    skillz^^
  13. stavrulezz
    stavrulezz New Member
    what variator,cylinder,exhaust,carb,reedblock u got on the aerox?
  14. phi1
    phi1 New Member
    Hi there I need the following if you have them!
    Speedo Drive
    Rear shock
    Front Mudguard
    Barends?
    Can you give me a price on each of those!
    Chears Phil
  15. waxhead
    waxhead Member
    im after the cases if you have them and they are in good condition
  16. Mp
    Mp New Member
    if you struggle to sell anything try popping the parts on Ebay, go pretty quick
  17. nrgandy
    nrgandy New Member
    pics of moast stuff now and prices
    front pan (not inc light) in good condition £35
    Wheels £20 each good condioton few small scrathes etc
    Front caliper £15
    Forks £45 good condition
    Front brake line £10
    engine with ginali pipe (no carb) £90 (6350 miles) pipe is verry rusty
    may spilt if theres no interest as a hole
  18. stavrulezz
    I want the front pan.But how much to ship to cyprus with ups??Its in europe.Also your selling the engine?cylinders are 50cc?
  19. nrgandy
    nrgandy New Member
    Headlight £15
    inner pan bit goes in front pan £8
    Horn £2
    Speedo drive and cable £10
    12mm carb with choke ant throttle cables £15
    Subframe and handelbars £3 each
    under pan bit £9
    Front lower pan few marks but looks good
    front inner £10
    lil inner pan £5
    clocks and surround with indys good condition £15
    battery covver and inner handle bar pan £5 each
    foot board has lil crack £10
    belly pan few scrapes on each side £10
    rear light £8 and oil tank £2
    Air box £4
    carbon look handel bit £4
    rear indys £8
    swithes £10 a side
    front brake master £6
    wireing loom £18
  20. phi1
    phi1 New Member
    Will take speedo drive only at 5er? The cable won't fit my bike and I already have a cable!
    phil
