hi i have recently changed my brake resevoir caps on my rox (putting on carbon fibre tnt ones have it!!!) i noticed that the lil tanks were dried up. what do i fill them up with and where can i get the stuff from to fill them up? do i have to mix the oil with anything? thank you
dot 4 or 4 brake fluid. should be able to get it from most car places. or even some garages(petrol stations.)
The oil is called fluid..brake fluid LOL james...james bond Use dot 3 or 4 (4 is probably right for your bike) and you can get it from mostly any car / bike shop..halfords have got it.. Then you will more than likely have to bleed your brakes.
chances are its low for a reason, check your brake pads, if worn then fit new before topping the fluid.
