aerox brake light flickering.
Discussion in 'The Workshop' started by dogtits, Jun 20, 2009.
  1. dogtits
    dogtits New Member
    aerox 70
    when you press the leaver in,, ( front or back) the brake light flickers,, i have checked over all the wires and they seem to be intact,, then when i took the leaver off and then i pressed the little pin in with my finger it worked fine :confused:cratch: will it be the after martket leavers that are causing it?
    cheers
  2. alperin
    alperin Active Member
    aerox 180cc
    make sure there screwed in all the way and yes after market levers can cause it not to work properly and do a check again take the switches out the lever and press them in and slowly depress them if they work properly then you need to change to standard levers.
  3. dogtits
    dogtits New Member
    aerox 70
    took the switch out and conected the wires up, then when i release the pin out slowly the light comes on let the pin out abit more and it goes off :confused:cratch: that mean i need a new switch? :mrgreen: Cheers
  4. MiNoR cOnFuSiOn
    yep...service item, they will break alot, its a cheapo switch. will sort your prob
